Roosa-Master/Stanadyne trasfer pump pressure
Phil
07-09-2003 20:23:12
Pulling 4230 jd in farm stock. Would like to know if my pump is up to par. What psi should my transfer pump be putting out? Will 130 psi make enough smoke?
Thanks,
Phil
Scott
07-10-2003 05:42:23
 Re: Roosa-Master/Stanadyne trasfer pump pressure in reply to Phil, 07-09-2003 20:23:12
130psi should be more than enough. Most pullers try to achieve around 50psi to the front side of the pump.
