Symco ,Wis
puller
07-08-2003 18:57:43
Anyone heard what is going on there with classes and such? Can you run a regular class and the run unlimited as a second class? Anything new going to happen now that i heard the dingaling that run it last year aint running it anymore? That would be the best thing to happen to the pull if they did get rid of him.
possible puller
07-09-2003 12:19:08
 Re: Symco ,Wis in reply to puller, 07-08-2003 18:57:43
Any rules for this years events??? I may be interested, what day is it on?? Greg
Flyin Farmall
07-08-2003 21:04:04
You can run unlimitted.There aren't any major rule changes,will be a little more difference between stock,and mods.It WILL go faster this year!
puller
07-09-2003 18:10:29
 Re: Re: Symco ,Wis in reply to Flyin Farmall, 07-08-2003 21:04:04
Is the unlimited a hook and go as it was a couple years ago? Why did they change it to a paced class? I thought it added somthing a little different to the show having a hook and go class.
4020PLUS
07-09-2003 06:16:06
WHAT CLASSES ARE PULLING THERE AND WHEN
Flyin Farmall
07-09-2003 20:29:27
 Re: Re: Re: Symco ,Wis in reply to 4020PLUS, 07-09-2003 06:16:06
The pull is Sat.July 26,Starts at 11:00.classes are;ANTIQUE1 38and older-32,35,4,45,5,6,7,8 and unlimited,ANTIQUE2,53 and older-3,35,4,5,6,7,and unlimited,MODIFIED-4,5,6,7.all are paced!basically no front weights in ant.1,front wheels Ant.2.,stock -10%Rpm's,except modifieds.No front cut tires.14.9 tire under 5500,18.4 above.I will be weighing tractors on Fri.from 1-5,if you want to come early.Feel free to e-mail any ?? [email protected]
t-puller
07-10-2003 15:39:46
 Re: Re: Re: Re: Symco ,Wis in reply to Flyin Farmall, 07-09-2003 20:29:27
Only one class per tractor yet?
Flyin Farmall
07-10-2003 17:45:14
 Re: Re: Re: Re: Re: Symco ,Wis in reply to t-puller, 07-10-2003 15:39:46
Yes,except unlimited
