Wide Front SM Puller
Krouthead
07-08-2003 15:14:44
Hey Bud,
Hope everybody is ok.Have you been stretchin' the chain,any?I hope ya'all come to Batesville.
Did you post Simsboro,LA results? Did you hear anything on the mysterious broke crank?
Take Care / Lots O Luck
Krout
Preston Matthews
07-10-2003 08:19:39
 Re: Wide Front SM Puller in reply to Krouthead, 07-08-2003 15:14:44
If you look at your picture in the Hook at the Tunica Pull you can see my tractor in the background next to the wall! I finally made it in the Hook!
07-09-2003 06:50:56
I am in the process of converting them to Excel, I have been gone since last Thursday, trying to catch some trout at Cotter, not much luck but the family and I had fun trying.
Will post results soon.
PHDM
Krouthead
07-09-2003 11:18:55
 Re: Re: Wide Front SM Puller in reply to Wide Front SM Puller, 07-09-2003 06:50:56
Did you jump in the spring? This causes an extreme problem called turtlecod.
Hope ya'all had fun you should have hollered, Id came and visited over a cool beverage.
Anyhow talk 2 ya later.
Take Care
Krout
Mr Animal
07-09-2003 04:27:37
I got this stright from the owner of said tractor. While test driving the tractor it started to lock up, so they shut it down, took it back into the shop and tore it down to see what happened. The tech could find nothing wrong with said tractor. The tractor was put back together and started. Said tractor ran and runs fine and they are not sure what happened. It was told to this reporter that the oniy problem with said tractor is not knowing what was realy wrong. That is all i have at this time, back to you. Animal
