M Farmall RPM John Deere 60 RPM Increase
Jason
07-05-2003 13:08:35
I was wondering if there is a way to get about 400 or 500 more RPM on a M Farmall. The tractor goes down the track with plenty of power and then all of the sudden runs out of power and kills the engine. If I can get it to the looser dirt it does better because it allows the wheels to slip a little.
I was also wondering if there is a safe and easy way to get another 250 RPM out of a John Deere 60.
randy hall
07-06-2003 14:38:14
 Re: M Farmall RPM John Deere 60 RPM Incr in reply to Jason, 07-05-2003 13:08:35
if you are pulling in low gear more rpm's won't help you because you will be going faster with more rpm's.
ChadS
07-08-2003 07:11:23
 Re: Re: M Farmall RPM John Deere 60 RPM in reply to randy hall , 07-06-2003 14:38:14
depends on the speed limit. The springs I offer can be set at stock rpms and still make a huge difference in the way the tractor responds during a pull on a Farmall tractor. Rpms help a little, depends on the limit you can run.
Jason
07-08-2003 11:35:34
 Re: Re: Re: M Farmall RPM John Deere 60 RPM in reply to ChadS, 07-08-2003 07:11:23
the strictest rules i have come across so far are stock tractors can't go faster than 4 mph And they want hand throttles so we cant put strings on the governors
ChadS
07-08-2003 18:28:27
 Re: Re: Re: Re: M Farmall RPM John Deere 60 RPM in reply to Jason, 07-08-2003 11:35:34
No, I would not want a string tied to my throttle! If you are interested in tring one of these spring I have for farmall tractors call me at 574-893-7437 Indiana time, I am asking 10.00 ea for the spring. It works! NO BS!!!! thanks CHADS
a puller
07-06-2003 14:30:48
put some wire or binder twine on the governor on the 60 and it will make it rap however hard you want it to, just don't go too far, for it can come unglued.
ChadS
07-05-2003 13:19:09
I have govenor springs that work well for farmall H-450. these springs will let you run up to 2600 rpm max, you could set the rpm for any speed you like. give instant throttle responce and low end power. Email me at [email protected] for more info
