WD45 Stock....what gear?
KB
08-06-2001 11:31:06
Can a stock WD45 (4 1/8) pistons pull 3500 pound class in 2nd gear? 14.9x28 tires? Assuming an averages track.
dave
08-06-2001 12:27:18
 Re: WD45 Stock....what gear? in reply to KB, 08-06-2001 11:31:06
You should be good. Watch the front end if it is a narrow . It may get light. Most 45's I pull against do well to 5000 lbs. you may want to run the tire pressure around 15 lbs. you will have the power.
GD
08-08-2001 20:38:39
 Re: Re: WD45 Stock....what gear? in reply to dave, 08-06-2001 12:27:18
We pull a WD45 Diesel with NF. Have had a problem with left wheel spinning first, took a weight off the right wheel and put it on the left side last week and it seemed to solve the problem
