Tires for a farmall M puller what is the best?????????
Jeremy
08-02-2001 09:52:30
I put together a farmall m and was going to pull it but the problem I have is to what size and brand of tires are the best its going to be in the stock class but I can run any size and brand of tires I want. I not sure on what size. I'm thinking of 13.8x38 or 14.9x38 or 15.5x38 does any one out there know what would be the best????? Any help you give would be great. Thanks jeremy
Farmall43
08-02-2001 20:47:22
 Re: Tires for a farmall M puller what is the best????????? in reply to Jeremy, 08-02-2001 09:52:30
Firestone 23degree bar. 15.5-38. pull in the highest gear it will spin out in. If you can find a set of used tires with about 50% tread. The older tires are harder and work better.
Jp
08-08-2001 15:20:29
 Re: Re: Tires for a farmall M puller what is the best????????? in reply to Farmall43, 08-02-2001 20:47:22
I agree with Firestone 23 or all traction field and road. But go with the 16.9 38. They are extremly hard to find, but we have them on our tractor and we dominate 5500 lb.
Jp
08-08-2001 15:19:41
farmall_H
08-03-2001 19:26:54
if u could find a set of safemark tires in 13.6x38, 14.9x38,or 15.5x38. it depends on how much motor u have. we have a M with only 13.6 of these tires and a realitivly stock motor and do quite well with it. it also helps a lot if the pulls u go to allow cut tires.
