MM Hubs
Bronson
06-09-2003 07:18:49
any one know what i could use for nine bolt hubs on a MM UB. First pull was last weekend and I split one pulling in 5500lb open. I was running 2nd gear and got to 100ft thats when it broke. I am running 18.4 - 34 tires with a little engine in front.Any help? Thanks
dave
06-09-2003 17:10:40
 Re: MM Hubs in reply to Bronson, 06-09-2003 07:18:49
we took m&w hubs and machined the key way to fit our ub key way.
jarrett
06-09-2003 11:20:21
I custom build 9-bolt hubs out of steel they weigh around 40lbs,have studs pressed into them and are alot stronger than castiron,i have a set on my g-1000 that pulls in the 12500 class.all of are other molines have theses on also have made 14 set of these for different people none have ever broke.the price is $500 a set plus shipping.if interested let me know.
Andy
06-09-2003 07:34:28
I found some JD hubs (3010 or something about that size). they are a bout -.010 smaller that than the 3" MM shaft. and have one key instead of two. They are fairly light and I think a little time and cursing with a die grinder they'll go.
