Turning up the fuel on WD9
Redonthehead
06-05-2003 20:43:24
Anybody got any info on how to turn up the fuel and rpms on WD9
Farmaller
06-06-2003 17:36:24
 Re: Turning up the fuel on WD9 in reply to Redonthehead, 06-05-2003 20:43:24
Take the oil filler cap off of the pump, there are three nuts, closest to the block is fuel adjustment. one in the middle is high idle the other is low idle. Adjust fuel with engine running on gas, open one injector, screw the fuel adjustment (which by the way has a locking nut) in until you have fuel coming through the injector. then back it off a little bit. The trick is in the governor. And the timing. You need to buy I&T shop manual IH-8. turning the fuel up wont make any difference if you don't get the gov. and the timing to work along with it. Hope this helps.
