6in stroked farmall M..problems?
Farmall Boy
06-05-2003 16:40:40
What problems would you run into putting a 6in stroke into a stock 39 M with super M kit??THANX YALL
Big 6 inch
06-06-2003 09:02:02
 Re: 6in stroked farmall M..problems? in reply to Farmall Boy, 06-05-2003 16:40:40
You'll need to find a piston with a compression height 3/8 inch shorter. You'll also have to do some clearancing on the block, rods, and camshaft. I'd try that 4020 JD piston with your M crank stroked to 6 1/8. That will give you about 345 cid. With the right carb, cam and head you can make 80-100 horsepower.
randy hall
06-05-2003 17:24:23
your pistons will be 3/8" too tall.
FB
06-05-2003 19:09:29
 Re: Re: 6in stroked farmall M..problems? in reply to randy hall , 06-05-2003 17:24:23
how much would rods cost?
