Is the old M ready or not?
Farmall Daddy
06-03-2003 13:25:17
Just spent about a year and a half on the motor work on my Farmall M, but I don't know if I should pull it right away or not. Bored it out to a bigger piston and changed the head on it. After a month of work on the timing, finally got it timed correctly and the carborator set pretty close. Went out disking with it on a 14ft. heavy frame disk and it did alright. Didn't quit run the best, so I put 4 new plugs in it with the gap of a dime. After that, I don't think I have ever heard an IH run that good in a long time. Put it in road gear, locked the brakes, and let out on the clutch. She held it w/o croaking out. Could I pull it this Saturday w/o dynoing it? Thanks!!
Boozing
06-08-2003 07:07:22
 Re: Is the old M ready or not? in reply to Farmall Daddy, 06-03-2003 13:25:17
Go for it, best way to find out is to pull, my boys and me pull a AC wd, took us 3 pulls to work all the bugs out, we had help and we asked a lot of questions at the pulls and everyone we talked with was more than willing to give advise to us, to me a great bunch of people to talk with, this helped us because we were new to it, we have been enjoying since.
Good luck
deadeye
06-03-2003 15:00:43
Go for it. You may want to put in a bigger ventura in the carb and open the air needle about wide open if it will run there.----deadeye
