What would you do to a Farmall M
FB
05-31-2003 17:42:36
If you had a 39 M ,with a super m kit, and where gonna put aroud 2000 dollars into it what would you do, its already lightened up and has electronic ignition, dry element air filter, and some head work.
Doug in OR
06-01-2003 21:30:24
 Re: What would you do to a Farmall M in reply to FB, 05-31-2003 17:42:36
First of all, tell us what you expect of this tractor. If you have the Super M kit, including 4.125 pistons, there's little else you can do in this area, short of stroking - which runs into $$$. Are you running out of power? Do you spin out well before you run short of power?
If you want barn-burning power as well as the traction to go with it, you'll need more than that $2000. Generally tires and weights would be the first consideration. Otherwise, decide where the weakness is and put your money there. It usually all comes down to balance.
FB
06-02-2003 18:28:41
 Re: Re: What would you do to a Farmall M in reply to Doug in OR, 06-01-2003 21:30:24
want it to be a 2nd gear puller all the time..wanting around 70 hp..already got tires weights weelie bars and all
Doug in OR
06-03-2003 18:40:10
 Re: Re: Re: What would you do to a Farmall M in reply to FB, 06-02-2003 18:28:41
It will be hard to get 70 hp from a stock block. The best you can hope for is around 55, without major engine mods. Go for the 450 pistons with the smaller wrist pins. Try for Firecraters, but if unavailable, see if someone offers high altitude pistons. Use an LP engine head, if you can find one. Get an LP intake/exhaust manifold too. Beware, changing heads may get you DQ'd in the stock classes. If you move up to modified, $2000 won't begin to touch what you need. This setup might get you hp in the middle 50s, which should easily pull in second in any conditions.
BTW, I pull in second half the time... using 16.9 tires and an old stock M engine. You really shouldn't need 70 hp.
FERG FARMS
06-17-2003 17:13:59
 Re: Re: Re: Re: What would you do to a Farmall M in reply to Doug in OR, 06-03-2003 18:40:10
around here you won,t pull 2sd with a stock motor.
(south west virginia)
G Taylor
06-01-2003 04:26:46
Pull the sleeves and run larger pistons.
GOT THE FEVER
05-31-2003 19:18:53
STROKE IT AND POSOBLY OPEN THE HEAD UP A BIT MORE MABEY LP?
piston
06-05-2003 19:41:21
 Re: Re: What would you do to a Farmall M in reply to GOT THE FEVER , 05-31-2003 19:18:53
sell it for scrape metal buy a mm go tractor pulling
