PLEASE HELP ME ON A FARMALL
Ethan Spencer
05-25-2003 22:16:20
how can i adjust the carb and govenors on a farmall H to get more pulln power what would be a good plug gap 4 a d21 champion sparkplug ,what would be a good tire pressure for tires about half full of fluid bottom line i dont know much about pulln so if anybody out there knows any cheap ways to help me be competitive iwould be very thankfull
Farmall Daddy
05-27-2003 16:14:47
 Re: PLEASE HELP ME ON A FARMALL in reply to Ethan Spencer, 05-25-2003 22:16:20
Well, this is what I do with my Farmall M. I set the plugs at .035 for a starter. My M was oversized when I bought it so I run the carb pretty rich when I pull and not so rich around the farm. I don't have fluid in my tires, but I ran somewhere around 7-10 lbs. in my tires {14-9-38's}. Another thing you might try is not running with the air cleaner hose connected to the carb, unless you already did that. It will increase air amount without any friction, which the air cleaner could be clogged and reduce your power at any given horse. Good Luck with your H!!
Dave A
05-25-2003 22:38:06
maybe raising your hitch for traction the higher you can legally have you hitch the better it puts more weight on your backend but takes it off your frontend so be carefull your frontend will raise up alot quiker
BIG RED
05-26-2003 09:04:13
 Re: Re: PLEASE HELP ME ON A FARMALL in reply to Dave A, 05-25-2003 22:38:06
pROBLEM WITH A H IS ITS WT. I HAVE ONE SET OF WHEEL WTS. ON WHEELS AND ONE LAYING ON DRAWBAR ALSO A 60 LB.WT. ON DRAWBAR, WITH ME ON IT WT.IS VERY CLOSE TO 4600 LB.THEIR IS NOT ENOUGH WT. THAT I CAN TAKE OFF WITH LITTLE EFFORT TO GET IN THE 3600 LB. CLASS, SO YOU ARE PULLING AGINST TRACTORS WITH MUCH MORE HORSEPOWER. IF YOUR TRACTOR IS IN GOOD SHAPE YOU WILL DO WELL ON A SOFT TRACK BUT WILL POWER OUT ON A HARD ONE.I THINK 9 TO 10 POUNDS IN TIRES IS ABOUT RIGHT, DONT KNOW ABOUT FLUID IN TIRES,
Mark
05-27-2003 12:18:30
 Re: Re: Re: PLEASE HELP ME ON A FARMALL in reply to BIG RED, 05-26-2003 09:04:13
First loose the fluid in the tires.Second,if the tractor is stock then set the governor,carburater,spark plug gap,and timing to factory settings.Pull in 1st & 2nd gear,2nd in light class 1st in heavy class.Try to pull in div.1,which is normally for your basic stock tractors.Go to the pulls and have a good time,don't worry about winning everything,it AIN'T gonna happen.Make friends with fellow pullers and ask for advice,they will help you.I don't have enough time to tell you everything I've learned in my 25 years of pulling and alot of can only be learned through expirience.Just remember this is all for fun,you're not gonna make a living at it.
