JD R, 80, etc with 23.1x26?
Brandon
05-24-2003 18:51:05
Just curious, do any of you pull your Rs or 80-830s with 23.1x26 rear tires? I've got an 80 that will soon get those tires (replacing the old too small 18.4x26)
Any suggestions on how much weight I should add? It is a stock tractor in stock pulls. (don't know the HorsePower as of yet-PTO needs fixed) Only weighs about 8500 at this point.
And I'm not gonna swap all the parts to get the taller 34 inchers. I'm not a big time puller, but would like to be competitive.
Thanks,
Brandon
My Industrial John Deere website
My JD model 80 website
Jim M
05-25-2003 04:09:06
 Re: JD R, 80, etc with 23.1x26? in reply to Brandon, 05-24-2003 18:51:05
I pull in South Florida. There are quite a few J/D of your size and other brands that use the 23.1 x 26 tires. Its a very hard track that we have most of the time and they usually don't do well. Some do and the key seems to be getting your drawbar up to the maximum height. Balalnce is a key also. Its seems to be hard to get more weight to the rear on those tractors. They all pull in the 10500 class. I don't think any of them are truly stock. They seem to smoke alot. My dad has 2 6 cyl CASE tractors that we pull and have changed them over to 18.4 x 34 to pull them and they seem to work better that way.
G Taylor
05-25-2003 11:54:12
 Re: Re: JD R, 80, etc with 23.1x26? in reply to Jim M, 05-25-2003 04:09:06
I agree. Even with the same foot print size, a tall narrow tire out pulls the short wide tire. Even a stepped rim to get 38" tires on the 80 would be better.
