Timing a stroker
New to this
05-20-2003 16:37:48
As a rule,does a motor thats been stroked take more ignition timing than when it was stock stroke? I understand piston speed will be faster but it will "dwell" longer at TDC so what would be the timing requirements.
TimC
05-20-2003 19:26:36
 Re: Timing a stroker in reply to New to this, 05-20-2003 16:37:48
I think less but make your own decision. I would however start it the first time with very little advance. Bad things seem to happen after one has ran backwards. Also use a seperate switch for starting and the ignition. It will save your starter a lot of heat and toil if you get it spinning over before you swith on the ignition.
Mark
05-24-2003 07:31:11
 Re: Re: Timing a stroker in reply to TimC, 05-20-2003 19:26:36
personally,I tune a Farmall M with 7 1/2 inch stroke and I don't use a timing light on it.I just open the throttle wide open and turn the distributor until the engine runs smooth and does not sound like it is laboring
