Kill switch
pullin'M
05-17-2003 07:14:12
I need some advice on how to hook up a break-away kill switch on a m farmall. I've got one for a trailer that completes a circut when pulled. Can I use that to ground the spark somewhere or will that just smoke the wire? What works the best?
Jim F.
05-19-2003 04:11:37
 Re: kill switch in reply to pullin'M, 05-17-2003 07:14:12
I used a trailer plug. I found a nice round chrome four prong round male and female. Put a stainless eye bolt in the male end for the cable to hook to the sled. This was the neatest I found. I don't like to use a trailer break-away unless the tractor has a mag; nothing like a direct short to fry something!
Jerry
05-17-2003 12:37:29
I use an electrical receptale and plug like on the end of an extention cord. Loop the wire inside the plug. I have spliced this into the wire from the on/off switch before the distributer. When you pull the plug it breaks the connection. Clamp the receptacle to the back of the tractor an add a ring to the plug to hook the tether from the sled to.
John
05-17-2003 10:54:01
You need to connect it to the small wire between the coil and distributor
pullin'M
05-18-2003 10:54:28
 Re: Re: kill switch in reply to John, 05-17-2003 10:54:01
Do you mean the ground wire or to the coil wire itself?
Jerry
05-18-2003 15:17:45
 Re: Re: Re: kill switch in reply to pullin'M, 05-18-2003 10:54:28
I assumed that you had a distributor and the wire that I used is the hot wire that goes to the + side of the coil. Break that connection and everything stops. If you have a mag. this will not work for you as you would need a switch that goes to ground . Good luck
