WC puller
geb
05-16-2003 12:34:53
I understand that there is a AC WC pulling tractor in the YT classified ads that the seller claims to have a 7 1/4 inch stroke with no deck plate between the block and the head. I know what I think, but what do you think?
don
05-16-2003 13:38:08
 Re: WC puller in reply to geb, 05-16-2003 12:34:53
If this is true i would not like to be near the thing when it pulls. To my knowledge there is no way that the crank will fit inside a standred WC block. I have one that is 6 5/16 and the sides are thin. And that is with 1 3/4 journals.
Terry
05-16-2003 12:47:40
"Stroke" has nothing to do with deck plates! The sides of the block and camshaft do! It's how small do you want to make the rod journal diameter, grind into the camshaft/block, and grind on sides of the rods!
geb
05-16-2003 13:12:03
 Re: Re: WC puller in reply to Terry, 05-16-2003 12:47:40
You have to have enough deck hgt and rod - stroke ratio to make it work.
TimC
05-16-2003 14:06:24
 Re: Re: Re: WC puller in reply to geb, 05-16-2003 13:12:03
It has to have windows in the block. If the compression height is short then it might work. It just wouldn't be as effecient.
Cody Adgent
05-16-2003 20:38:44
 Re: Re: Re: Re: WC puller in reply to TimC, 05-16-2003 14:06:24
I'm the one who posted the ad. I posted the tractor for a friend of mine and I got my information crossed up along the path. The WC has a 4.125 bore x 6.25 stroke, it is 355cid. Sorry about that, I apologize for any brain cells that ya'll might have waisted on that 7.5 mystery!
geb
05-17-2003 06:45:18
 Re: Re: Re: Re: Re: WC puller in reply to Cody Adgent, 05-16-2003 20:38:44
Thanks Cody, that clears it up. I was wondering if ther was something I was missing about the situation.
Scott
05-19-2003 05:23:43
 Re: Re: Re: Re: Re: Re: WC puller in reply to geb, 05-17-2003 06:45:18
Sure am glad you got that straightened out. I didn't sleep for 2 nights trying to figure it out!
