9 bolt hubs for John Deere G
JD720
05-13-2003 10:53:03
What is the best method for mounting 9 bolt wheels on a G ? Can you use the hubs from the cast centers and make an adapter plate or do you have to use the weld on plates? Does anyone make these plates for either adapting the cast hub or welding on or is this something I will have to make myself ? Any help is appreciated. Thank you
LRN
05-14-2003 06:41:05
 Re: 9 bolt hubs for John Deere G in reply to JD720, 05-13-2003 10:53:03
The adapter plate works great. There is a guy from Iowa that makes them for about $100. I think he advertises in the Hook, Green, and 2 Cylinder magazines.
Lee
05-14-2003 19:27:43
 Re: Re: 9 bolt hubs for John Deere G in reply to LRN, 05-14-2003 06:41:05
The man Is from Wisconsin. His name is Dave Brugger his Phone number (608) 762-5517. He will set you up. He also pull a John deere G. I bought some for my farmall H for $100 bucks from him.
Gpower
05-13-2003 11:26:32
The best method is to just make some adapters to go from the cast hub to the 9 bolt center. Pretty easy to do and looks good, just take your time. Good Luck
