Tire width
TIM KELLER IN P
05-10-2003 07:17:20
I hahve 16.9/28 tires and wheels is it possible to sucsessfully put skinnier tires on that particuler wheel
Jim M
05-11-2003 08:14:38
 Re: tire width in reply to TIM KELLER IN PA, 05-10-2003 07:17:20
The 16.9 x 28 should have been on 15" rims if done right by whoever did it last. 14.9 x 28 tires should fit OK on them but I wouldn't go any smaller. Check the rims to see how wide they are between the inside of the rim beads and let us know back
Dave
05-10-2003 07:48:14
The rim width will determine if you can successfully use a narrower tire. You will also need to know how heavy you will be loading tractor, you DON'T want rim to blow apart!!!!!
OLDGEEZER
05-10-2003 10:39:52
 Re: Re: tire width in reply to Dave, 05-10-2003 07:48:14
stop messing around with those sissy tire sizes, HECK use some 20.8x38's and get some real traction, I tell you what you sissy boys dissapoint me.
No one alows 20.8
05-11-2003 23:53:40
 Re: Re: Re: tire width in reply to OLDGEEZER, 05-10-2003 10:39:52
Where can u pull 20.8's? Where did u find a set that aren't radial? Everywhere we go 18.4 is the limit and NO RADIALS.
I want 20.8's but can't have em!
