MM M-5: Can they be made to pull?
KB
07-26-2001 07:41:20
I am curious if an M-5 (gas or diesel) can be made to pull? I know what can be done with a U/UB (bore and stroke), but what about a diesel and putting a turbo on? Are the injection pumps worthless and would heads off a G-900 or 1000 work better regarding a diesel. Back to a gas, does a stroked crankshaft work better than standard if you plan on running a lot of RPM's?
G Taylor
07-26-2001 16:20:52
 Re: MM M-5: Can they be made to pull? in reply to KB, 07-26-2001 07:41:20
Rather than destroking the crank to limit centrifical force use lighter/stronger components. Titanium rods & lighter pistons.
KB as well
07-26-2001 09:20:11
One pulls in my area that is very tough. He runs 600+cid with 800 square port heads. He also turns alot of RPM for the cubic inches.... around 4500RPM.
