When do you need 9bolt reinforcement rings??
tractor puller2
05-04-2003 12:54:19
at what point or HP do you recommend that a person use a reinforcement ring in your pressed steel wheel and what thickness is best??
smith
05-05-2003 07:18:43
 Re: when do you need 9bolt reinforcement rings?? in reply to tractor puller2, 05-04-2003 12:54:19
i know someone who has 1/4" 9 bolt reinforcement rings for $45 per set. can also make to your specs. discounts for quantity purchases. email for more info
JD Puller
05-05-2003 05:35:29
Just a guess, but I would say around 100 hp. I run lightweight centers on a hot farm tractor with reinforcement rings from M.E. Miller tire.
Around $30 bucks each and they are 1/4" thick.
