Is it light enough???
Pulling Prodigy
04-25-2003 14:40:22
We have a '39 M and have just about got done lightening it up. But our first pull is tommorrow and we won't have tim to weigh it. SOOOOO do yall think we can get a '39 M into 4500 with no lights, belly pump, pto, side pulley, we are running on full pressed steel, only front and rear weight brackets, homemade hitch weighin about 20lbs, stock shortened drawbar, new 14.9's, and alm. gas tank....WILL WE MAKE 4500 and do any good??
39M@Hpuller
04-25-2003 18:25:13
 Re: Is it light enough??? in reply to Pulling Prodigy, 04-25-2003 14:40:22
my 39M is set up pretty much the same way. 5x15pressed steel on the front and 16.9x34 on the rear. I weigh 4150 with out me and 5 gallons of gas in the tank.
deadeye
04-25-2003 14:55:50
You will probably have to add weight. Only run about 5 to 7gal of gas also.
