Tractor Pull at Ingham co. Fair
Matt
07-22-2001 14:55:44
On Aug 1 2001 at 1pm weigh in for the antiuqe and classic tractor pull will begin. Anyone interested please contact www.leslietractorclub.com This is in Mid michigan. About 15 miles south of lansing. The fair grounds are located in Mason MI. Thanks and hope to see you there. Oh by the way most all the weight classes are dominated by Red Iron. So bring what you got and hope it is enough.
Mike
07-22-2001 17:51:14
 Re: Tractor Pull at Ingham co. Fair in reply to Matt, 07-22-2001 14:55:44
how many hooks per tractor in the open classes
Matt
07-23-2001 10:47:34
 Re: Re: Tractor Pull at Ingham co. Fair in reply to Mike, 07-22-2001 17:51:14
In the Limited open classes you are allowed on hook per weight class. You may enter as many as your tractor will fall into. Say you tractor weighs 5500 you can pull in 5500,6500,7500,ect.
Mike
07-23-2001 12:34:12
 Re: Re: Re: Tractor Pull at Ingham co. Fair in reply to Matt, 07-23-2001 10:47:34
I heard it was one hook in one weight class per tractor to save time and keep the pull from taking too long.
Matt
07-23-2001 23:48:37
 Re: Re: Re: Re: Tractor Pull at Ingham co. Fair in reply to Mike, 07-23-2001 12:34:12
Being at the fair that may be possible. I know at the home track we pull the same tractor in multiple classes. You might want to check the web sight and ask there. They might have an answer for you. The Address is www.leslietractorclub.com This will be the first year I have pulled at the fair. I work afternoons and decided to take the day off this year. Good luck and hope to see you there.
