Weights for 9 bolt wheels...
FM
04-18-2003 04:18:25
Eventually, I am going to own a Farmall M which will be pulled at a few local fairs. I am going to find a set of 9 bolt wheels for it, hopefully 15.5x38s. My oliver 70 has a set of 9 bolt wheels, only they are 11-38s. Will both wheels use the same weights without drilling new holes?? If not, what do the weights for the 15.5x38s look like or what ones would work?
Mike
Jeff
04-18-2003 12:17:41
 Re: Weights for 9 bolt wheels... in reply to FM, 04-18-2003 04:18:25
They will work as long as you have Oliver weights. frmall weights won't work unless you drill new holes and they will still not fit flat against the wheel completly. Personally on our Super M we kept the cast wheels and used IH weights. In Farm Stock classes the M's really pull good when they are up around the 5500 and up classes around here.
They should
04-18-2003 07:57:16
a
