OT Kiddie Tractor
Farmedic
04-16-2003 12:38:34
Could or would some one help me with the gear ratio and or plans to modifiey a tractor to be used for kiddie tractor pulls for our fire department. Thank You
TNDEAN
04-16-2003 21:05:06
 Re: OT Kiddie Tractor in reply to Farmedic, 04-16-2003 12:38:34
Medic, you cant go have a real big sprocket in the back.I have taken the whole rear axle out and replaced it with other parts,using 1 half inch shaft,2 pillow blocks,two wheel barrel wheels and two 12 inch tractor lug tires.drive train is two sprockets and a #50 chain.I have a pin in the axle to make both wheels pull .I have built some that look like smoker tractors.e-mail me with the tractor type you are using,and I will help you out.Itl cost you around 100.00$to get the right set-up for 4-12 year olds.....TNDEAN
