Need some help, Please
Texas Red
07-22-2001 03:45:17
I have A U9 motor and it has flat top pistons, The Head is # 8320 DB (What head is this?? REG Or High Comp, Or propane ( It was set up to run on natural gas. What carb did this unit use??
I also Have another motor that came out of a W9, Thead was gone but the motor was good before the head was removed, ?? The pistons in this motor are steped, the step is 3/8" high and the low part of the piston comes out above the block about 1/16". What type of pistons are these?? Are these pistons High Alt? if so which ones?? The pistons in the u9 are down the block about 1/8" Thanks for any and all Help TR
