Mag or Distributor?
MM
04-13-2003 06:27:34
What do you perfer to use on a almost stock puller? I have been told a mag has a hotter and longer spark than distributor. The mag is a H-4 farmall. Thanks.
770
04-16-2003 16:58:39
 Re: Mag or Distributor? in reply to MM, 04-13-2003 06:27:34
Use whats origional. Pulling stock it doesn't make a difference. Anyone out there who doubts a mags ability to spark hot, ask yourself why the $100,000 top fuel dragsters use them???
lighter to run..less weight
04-17-2003 14:55:35
 Re: Re: Mag or Distributor? in reply to 770, 04-16-2003 16:58:39
Irv
04-14-2003 11:53:51
There is more than just spark to consider here. A properly working distributor will advance the spark timinmg as engine rpm's increase; this gives you a better power curve. A mag only has 2
timing settings. Start and running. With a mag,
after the engine reaches 200 or more rpm's, some weights inside the mag swing out and advance the timing 10 to 20 degrees. If you listen to some tractors using a mag, you will notice that at idle some sound like they are laboring just a little bit. Too much spark advance at idle.
allisguy
04-14-2003 07:13:29
It is my understanding that a magneto will actually make a hotter spark but it takes more horsepower to turn it than a distributor. I have run both types of ignition systems on a variety of motorsports and racing applications and I believe that its a toss up. Put your energy towards something else.
Regards, allisguy
a puller
04-14-2003 04:25:41
I have always been told that a distributer is hotter, but on an almost stock tractor, a mag should be plenty fine. My grandpa has a JD A that is mostly stock, and he runs a mag and it runs good.
mo spark
04-13-2003 18:41:39
R U sure?
MM
04-13-2003 19:16:58
 Re: Re: Mag or Distributor? in reply to mo spark, 04-13-2003 18:41:39
Thats what a older tractor puller told me. He said a mag has a Hotter spark and longer. I really don't know.
