M Farmall Rods
Wild Horses M
04-10-2003 12:30:32
I am rebuilding my motor with 409 Chevy pistons, but I ran into a snag. I need about a half inch longer than stock rod. Does anyone have any suggestions? I'm looking to get it running for June pulls. Could I cut two sets of stock rods and lengthen them by welding then together? I have access to a wire welder.
fergufarms
04-13-2003 05:37:43
 Re: M Farmall Rods in reply to Wild Horses M, 04-10-2003 12:30:32
you might have the pistons made for about the same cost as havig the rods welded .
fritz
04-12-2003 08:00:04
Afriend of mine runs welded rods in a limeted pro.Ben in there for 5 years.Turns 5200Rpms with a turbo.I would say you are not welding them right.
James Tierney
04-11-2003 22:14:48
An Oliver 80 rod is 1/2 inch longer than an M. It is not a canted cap, so cam clearance is a consideration. Also, the journal diameter is about 2 3/8 - you could offset grind your crank to meet your exact need.
randy hall
04-10-2003 21:16:15
if i were you i would get a crank that has been stroked an inch, like the other fellow suggested. i had a welded rod break once, and it's a good way to ruin your day.
john jr.
04-10-2003 16:36:13
if you know what you are doing, lenghten the rods, adding material to the inside of the beams, proper welding, will last as long as stock rods. cheaper than stroked crank.
joe
04-10-2003 15:45:06
Stroke the crank an inch.
max puller
04-10-2003 15:44:29
Welding rods together is a bad idea, its not will they brake its when!!!!!
