JD G starter
Derrick
04-07-2003 13:53:39
Having starting problems need more starter have stock hooked up 24v not going to last. Checked archives seen once before somthing about Ford psd
and bobcat starter fitting what years or models and what does it take to make them work. Thanks for any help.
al
04-08-2003 15:11:00
 Re: JD G starter in reply to Derrick, 04-07-2003 13:53:39
Ther is an ISKRA 4020 Diesel starter that works good bolts on with no crank cover mod.around $275.00 new no exch. Diesel Inj service in Wi.
608-837-7358 also have a web site
Sandyland Puller
04-07-2003 17:06:56
The Delco part number for the starter I used is 1113281. It is a gear reduction starter but still needs the petcoks open. It cost about $230.00
A puller
04-07-2003 15:54:02
We use a starter out of the later 466 motors. Bolts right in not as pricey as the 8.1 gear reduction ones. They are heavier though.
Gpower
04-07-2003 15:47:57
Get you a starter of an 8.1 JD Engine. its gear reduction and bolts right into the stock frame of the G. Lots of power. Gpower
