Spark plugs for JD's
mark
04-06-2003 07:38:56
Can anyone tell me what kind of spark plugs to use on a JD B
2 cylinder
04-06-2003 12:20:23
 Re: Spark plugs for JD's in reply to mark , 04-06-2003 07:38:56
Alot of 2 cylinder pullers recommend an AC C-87 or C-88 for a hot spark plug that doesn't easily foul, with the C-88 being the hotter plug of the two. I use the C-88 in my JD-B, A, and G. There are others that will recommend other brands also, but the AC brand has never let me down. My 2 cents.
rusty
04-07-2003 15:54:12
 Re: Re: Spark plugs for JD's in reply to 2 cylinder, 04-06-2003 12:20:23
If the B does not have a bunch of compression, ie fairly mild, I agree that a C-88 would be fine, if it is 9:1 or higher and your running high octain gas, run a little colder plug, a C-86, so not to score the block lining or head of the piston.
