Pulling tire rim size
Mikek
04-05-2003 13:28:45
Wondering what the rim width should be on an 18.4x38 tire? Some people tell me 16" others tell me 18" Need some expert advice.Thanks
Ohio Puller
04-06-2003 05:47:49
 Re: Pulling tire rim size in reply to Mikek, 04-05-2003 13:28:45
Somewhat depends on what air pressure you are going to run.
Mike Aylward
04-05-2003 15:14:15
Mike, if you are planning on cutting your tires an 18" rim is just right. The 16" rim is the factory recommended rim size for an 18.4 tire for field use but an 18" gives you a squarer profile on the tire. Some folks use wider rims on their tires but with the advent of machine cutting there really is no advantage anymore to having a super-wide rim on a tire. I do custom machine cutting and most folks I cut tires for use an 18" rim and they work very well. Mike
