JD A rods/pistons
MATT
04-04-2003 11:08:55
Looking for some advice for a rod/ piston combo for a JD A with a 8 1/2" stroke crank, or a source for custom pistons and rods.
Gman
04-04-2003 18:44:20
 Re: JD A rods/pistons in reply to MATT, 04-04-2003 11:08:55
Matt try Schooler Motorsports email [email protected] he can set you up with about anything concerning John Deere.Later Garland
G-MAN
04-04-2003 13:37:10
I believe Murphy Motor Service can build custom connecting rods, as well.
MATT
04-04-2003 13:42:42
 Re: Re: JD A rods/pistons in reply to G-MAN, 04-04-2003 13:37:10
Got a number for Murphy?
G-MAN
04-04-2003 15:32:51
 Re: Re: Re: JD A rods/pistons in reply to MATT, 04-04-2003 13:42:42
Go to www.murphysmotorservice.com
TimC
04-04-2003 11:19:49
Cunningham Rods, expensive. They can be welded but not very many people know how to make them last. If you ever find anyone who runs a CNC machine they could cut a set out of 4130. It would still cost you but might be worth it.
Just opinions.
Fritz
04-04-2003 19:21:16
 Re: Re: JD A rods/pistons in reply to TimC, 04-04-2003 11:19:49
TIM,Idont know what you think of welded rods.But I have a frind that has a limet PRO.410 C.Iturns 4600.R.P.M.s and they are welded by by Merfeild.
TimC
04-04-2003 20:22:54
 Re: Re: Re: JD A rods/pistons in reply to Fritz, 04-04-2003 19:21:16
I also have a friend with a wd45 4.5 by 6 bore and stroke and he gut checks it all the time and they have lived for several years now. The first set was made by someone out of state that was supposed to be reputable. It trashed the block on its first pull. The set he has now have even had propelyne oxide (spelling) put to them. So that is why i said what i did. I wouldn't hesitate to use them if i was sure the welder knew what he was doing, had a good understanding of metalurgy and knew how to normalize the rods in the cool down process. Hope i have help and not confused the issue.
(spelling)
