Symco Pull
Oliver 88 Pulle
07-19-2001 08:16:57
Hey folks,
Thinking about heading to the Symco pull next Saturday July 28. Can any of you that are going give us a heads up on specific rules. Such as:
stock drawbar required? and height
hang-on weights
RPM limit
tire size (I believe no front cuts are allowed)
and any other info you think is helpful.
Thanks in advance, Brian.
Flyin Farmall
07-19-2001 21:27:45
 Re: Symco Pull in reply to Oliver 88 Puller, 07-19-2001 08:16:57
you can have weights no more than 17"from center of front axle'24"from rear axle except on platforms'no front cut tires,or adding lugs,drawbar height is 20" 18"from center of axle' 3 mph speed limit,no rpm limit this maybe next,let me know how you feel about a pure stock,or a mod class for next year?
Chuck M
07-21-2001 06:52:18
 Re: Re: Symco Pull in reply to Flyin Farmall, 07-19-2001 21:27:45
Flyin Farmall are you a member of the the Symco club? We are thinking strong about a weight rule for stock classes at Valmy as I am a member of that club.
Flyin Farmall
07-21-2001 08:54:25
 Re: Re: Re: Symco Pull in reply to Chuck M, 07-21-2001 06:52:18
yes i'm a member.i've been to your pull the last couple years,it is a good pull!If your trying to weed out modified tractors,or just make it fair?eliminating add-on weights is not the answer.you guys are doing a great job now,just get that damn hole out of the track.are you coming down next weekend?
Chuck M
07-21-2001 16:03:39
 Re: Re: Re: Re: Symco Pull in reply to Flyin Farmall, 07-21-2001 08:54:25
yes, I am. We are thinking of splitting classes
Flyin Farmall
07-22-2001 11:31:34
 Re: Re: Re: Re: Re: Symco Pull in reply to Chuck M, 07-21-2001 16:03:39
how are you gonna split them?stock and modified? are there any rule changes this year?
Chuck M
07-22-2001 16:02:31
 Re: Re: Re: Re: Re: Re: Symco Pull in reply to Flyin Farmall, 07-22-2001 11:31:34
no changes for this year. next year hang-on weights aloud in a super class. stock classes bolt-on only,no weight brackets.
Flyin Farmall
07-21-2001 08:53:42
