SATPA
Mike
04-02-2003 19:57:21
Here is my opinion on the SATPA situation.
1.A super M or 450 Block absolutely would be a factory replacement for a M documented or not!!!
2.There are plenty of stroker motors pulling stock in the area right now, so why worry about an Super M motor in a M?
3.And as far as the Massey goes it is a beautiful tractor but as far as HP goes not overly impressed.It can`t run with the others in the area.I would like to puy my 460 IH against it to see what would happen?? Just my .02 cents
farmallflogger
04-02-2003 21:31:44
 Re: SATPA in reply to Mike, 04-02-2003 19:57:21
Well here's the deal Mike. The rule's in place because a puller's son on a 281 inch M got out-pulled by another M with a 264 block. I thought the members should've got a vote on it but we didn't. I guess you could say it was a personal favor to the puller's dad. The offending tractor elected to change blocks and comply with the new rule. Unfortunately for me I had bought a block and crank, paid shipping from MO to NC, and had them in the machine shop before I ever heard of the rule.
Now if had just been that and nothing else I'd have probably just pulled somewhere else and kept quiet, but the owner/promoter owned a model L Case with a 3cyl Detroit conversion kit on it. He claimed to have factory doucmentaion for it etc, etc. When the smoke cleared, the 264 cid M was out but the Detroit Case was in.
That's about the most ridiculous thing I've ever heard of. I really don't care who authenticated it. It's wrong from an ethical standpoint. If I were pulling an L model case in a stock class and was told I'd be pulling against one with a Detroit I don't think I'd bother to unload. Conversely I think if they took the mule to another association to pull a stock class, they'd be told not to bother unloading either.
For argument's sake lets say a 264 block has some potential HP advantage over a 248. I'll have to agree there is some. How does that compare with the advantage a supercharged 3-71 Detroit has over a standard model L engine? I'm not a Case historian but I'm guessing you won't find a 3-71 in the model L Case parts book either. I'd be trying to get rid of that tractor too.
The up side to the story is that the other pulling associations around here allow up to a 450 engine on an M. I think it's a good rule.
Regards John Hinson
LW
04-03-2003 04:43:48
 Re: Re: SATPA in reply to farmallflogger, 04-02-2003 21:31:44
Hey John, I would say for boring out big the M block would have the advantage they are a little thicker on the bottom deck more to work with, that is the same series thractor and it is not a stock replacement, I got an Idea lets build a real big engine all stuffed in a M block , then the'll find something else wrong, bottom line if you were not real competetive and or beating your competition you would'nt here a thing about it..Lawrence Wilson
Your Lollipop
04-07-2003 16:36:03
 Re: Re: Re: SATPA in reply to LW, 04-03-2003 04:43:48
Hey, LW - Rumor has it that you're just upset because you got that nasty Moline yellar licked off your lollipop last October at a SATPA pull!
farmallflogger
04-03-2003 18:14:34
Lawrence I got a flier from Tomlin Mills' this week. Don't know if you ever pull up there or not but I noticed the super classes are open gear. I'm almost positive there's no speed limit either. Nice hard packed 250' track and lots of shade in the pits. I'll bet you could really turn those fast steppin Molines loose up there. You may be going somewhere else sat but they pull the first sat every month.
Later John H
LW
04-03-2003 20:25:37
 Re: Re: Re: Re: SATPA in reply to farmallflogger, 04-03-2003 18:14:34
That is one nice place, the shade helps out alot, its about 3hrs or more for me though, the pittsboro pull is only an hour, but I will try to get there some this year, see you at pull.LW
