Farmall H
steve roberts
04-01-2003 17:02:33
Farmall h tractors are beautiful to my eyes but always end up pretty far back at our antique pulls. we are allowed overbore and 700 pto speed. other than that playing with tires and weights. any hints would be appreciated. thanks steve robers
fergufarms
04-13-2003 06:31:55
 Re: farmall H in reply to steve roberts, 04-01-2003 17:02:33
350 pistons are right.we have a h pulling 4000 lbs 4.5mph.1st-2oo1 2sd-2002. 2sd gear.you will still need head word done unless you are planning on pulling in 1st gear only.
missery
04-02-2003 15:19:30
hello . the 700 rpm pto sounds familer. where are you located? what class are you in? just curious.
hpuller
04-01-2003 17:09:39
Bore your H out and put in 350 pistons with high dome pistons. This will make your H very competive.
matt
04-01-2003 18:21:40
 Re: Re: farmall H in reply to hpuller, 04-01-2003 17:09:39
How much money does it take to bore it out and put 350 pistons in it? Thanks.
hpuller
04-02-2003 17:36:20
 Re: Re: Re: farmall H in reply to matt, 04-01-2003 18:21:40
Go buy a rebuild kit for a 350 with pistons and sleeves($300-500) and get the block bored ($20-40 a hole) Doesnt cost much more than a normal overhaul.
