Pulling M
Laughs Like Thu
03-30-2003 16:05:37
I'm building and early M for pulling. Does anyone know the bore size of the BLOCK(after the sleeves are removed)and what pistons I could run in the block without sleeves? No stroke will be added. Thanks for any information. I am new to the sport.
Farmall Daddy
04-01-2003 16:31:03
 Re: pulling M in reply to Laughs Like Thunder, 03-30-2003 16:05:37
You can run the motor without sleeves, but you couldn't use it as a farm tractor. I am not sure, but I would imagine that you could fit either 4 1/4 or 4 3/8's. Better check with a Famall M puller. I do pull an M, but I am running 4 1/8 inch pistons in it w/sleeves, which I had to bore the motor out to fit them. If you can find them, bore the block, and put 4 1/4's in it. Good Luck!!
LTL
04-06-2003 09:37:12
 Re: Re: pulling M in reply to Farmall Daddy, 04-01-2003 16:31:03
thanks for the information iwill let you know how i make out.
