Spark plugs
Dave
03-28-2003 09:21:53
I have a IH 400 that we pull with that we just did a valve job on, shaved the head .100, 4 1/8 bore with M&W high compression pistons, stock stroke. We have been using Champion D15Y plugs. I understand that with higher compression using a colder plug is better. Am I wrong in that? What plug would you recommend that I use? Thanks for the information.
bruce
03-29-2003 14:15:37
 Re: spark plugs in reply to Dave, 03-28-2003 09:21:53
HI I used to pull a 400 with the same specs. You are correct in using a colder plug with higher compression. however my guess is that you are still under 10/1 The D15 heat range should be ok If detonation should happen on a warm day switch to a colder plug. I have always had good luck with Autolight plugs. Indexing the plugs-electrode down may help performance also.
