John Deere 60 (need more pulling power)
Jake
03-27-2003 18:59:07
I have a J.D. 60 gas, and was wondering if a propane manafold would help add a little more power for pulling.
G-MAN
03-28-2003 10:23:34
 Re: John Deere 60 (need more pulling power) in reply to Jake, 03-27-2003 18:59:07
It certainly won't hurt, as the regular gas manifold does heat the intake side to some extent, even when the diverter valve is in the "cold" position. However, you might experience carburetor icing in certain conditions. That is what the diverter-style manifold was designed to prevent. You're probably not going to see any big increase in power either way. To do that, you need to increase compression, displacement or airflow.
