MM M5 jugs
Frank
03-19-2003 10:36:14
how far can you bore a set of M5 jugs without getting into trouble. I've heard 1/4 inch. any info is appreciated thanks.
dieselbear
03-19-2003 14:04:06
 Re: MM M5 jugs in reply to Frank, 03-19-2003 10:36:14
4.81 is about the limit. I make new blocks that can be sleeved to 5.75 if your interested.
Andy
03-19-2003 15:42:05
 Re: Re: MM M5 jugs in reply to dieselbear, 03-19-2003 14:04:06
Do you make 403 blocks like this?
Dieselbear
03-20-2003 03:26:19
 Re: Re: Re: MM M5 jugs in reply to Andy, 03-19-2003 15:42:05
Yes, I can make both short and tall blocks. Will be an add in the Hook in May issue. Or can e-mail you pictures
Andy
03-19-2003 13:48:37
Welters sells 4.81 pistons I would think the sleeves that extend into the crankcase would be prone to cracking if you went much more.
