What tractor should I look for?
Johnboy
03-16-2003 18:53:02
Thinking about getting in to antique tractor pulling. I have half a dozen freinds that pull and I am tried of sitting in the stands watching. I would like to pull a John Deere but I do not know what model or year to look for. I dont have to win i just want to have some fun and be some what competitive. What tractor should i look for? Your opinions please!
2 cylinder
03-18-2003 19:40:29
 Re: What tractor should I look for? in reply to Johnboy, 03-16-2003 18:53:02
If you are going with mostly stock John Deere antique's for pulling, I would go with a Late model John Deere B or A (1950-52) simply because they are not as likely to power out with the low first gear, or the 50 and 60, if the rules allow. If your going to put some performance parts into the motor then most of the JD models can be made competitive with some performance parts for the motor. I pull a 41-B, 47-A, and a 51-G John Deere's.
a puller
03-16-2003 19:14:14
get a John deere A, if pulling on cement at all, go with a 50-52 A, if going on almost all dirt, go with either an unstyled, or any A up to 46, unless u want the pressed frame, then go up to 49, u just don't want a slow low on dirt.
Dick
03-16-2003 22:17:23
 Re: Re: What tractor should I look for? in reply to a puller, 03-16-2003 19:14:14
Pick a brand you are the most familiar with. The more familiar you are with the model the easier it will be to find parts to lighten the tractor and get more power.
2cents
