JD B how far to stroke ????
Paul
03-04-2003 21:04:08
A freind of mine is wanting to stroke a B. What is a reasonable goal without having to cut the case up too much? also what rod is a good place to start. thanks for all help Paul
A puller-to kmc
03-10-2003 19:07:40
 Re: JD B how far to stroke ???? in reply to Paul, 03-04-2003 21:04:08
can you tell me a little more on what u did, and was their more room to put a 2" journal in it? what all did you have to move and stuff. Looking forward to your email.
a puller
KMC
03-04-2003 23:28:56
I had a JD B stroke out to 8 1/4 ran three years then broke the crank. Rods were 1 3/4 diameter.( that is to small) I made the rods out of alum.
7 1/2 should last with bigger journal.
JD B Puller
03-06-2003 04:42:07
 Re: Re: JD B how far to stroke ???? in reply to KMC, 03-04-2003 23:28:56
How tall were the pistons in your 8-1/4" stroked B?
KMC
03-06-2003 06:38:09
 Re: Re: Re: JD B how far to stroke ???? in reply to JD B Puller, 03-06-2003 04:42:07
39 Block and under the spark plugs
