Pulling cam
JDA
07-11-2001 04:36:55
My dad and I are fixing up a late "A" for me to pull with. Does anybody make NEW pulling cams for my tractor? thanks.
Brad Gray
07-11-2001 11:32:10
 Re: pulling cam in reply to JDA, 07-11-2001 04:36:55
Has anyone ever made billet cams for these tractors (2 cylinders?)? I have made several for different prostock, suoerstock, and modified stock tractors. The billet allows you to come up with any profile not just limited to regrinding from stock profile. Rather costly, but how bad do you want to win?
Goldsburg
07-18-2001 08:12:51
 Re: Re: pulling cam in reply to Brad Gray, 07-11-2001 11:32:10
Brad -
The same can be done with a "stock" cam for considerably less money. It involves "building-up" the lobes, grinding new profiles, then heat treating the entire piece, as it has been totally annealed for the build-up process. Unfortunately, there are very few places that will do this process but it works VERY well.
Goldsburg
Jeff
07-25-2001 11:59:44
 Re: Re: Re: pulling cam in reply to Goldsburg, 07-18-2001 08:12:51
Goldsburg,
where is such a place that i could get the stock cam reground to run higher rpm nonturbo big cube motor in a case.
Brad,
How much we talkin' thanks Jeff
