Tractor Suggestions.
Greg H.
03-20-2001 10:25:10
Here's the Senerio. The tractor club that I am a member of has a natural asperated class that has hooks for 5000,6000,7500,9000,and 10000. The major rules are stock appearance block fuel pump, and 20 inch drawbar higth. You can't run cut tires, but there is no speed limit, no gear restriction, but if you are going to turn more than 3,000 rpm,s they want you to run a machined flywheel. Needless to say, I want to go HOT! Also in the two lower classed you cant run larger than 15.5x38's, but from 7500 and up you can run 18.4x38's. The tracors that are primarily ran in the lower classes are oliver88's, farmall M's and JD G's. I would like to run something different, mainly for the piss-off affect, but that's not everything. So fella's if those were the main rules that you'all had to go by when diciding to build a tractor, what type and model of tractor would you build? I personally don't have a preferance, but I will probobly have a budget of about 6 to 7 thousand dollars. This is next years project, and I'm not in a hurry to find one, but I just want to get an Idea about what I'm going to look for. By the way this is not an antique class, but I was thinking of something older, due to cash constraints. Plus there is an antique class with virtually the same rules, so I might want to keep it prior to 1960. all information will be apprechiated. Thanks Greg H. P.S. I'm not trying to start a brand argument, I just want the pro's and con's of building the best pulling models from their respective manufacturers. Thanks again.
MN.MM
03-20-2001 19:46:10
 Re: Tractor Suggestions. in reply to Greg H., 03-20-2001 10:25:10
WHAT A WAY TO GO, PRAIRIE GOLD!
tommyw
03-20-2001 19:31:25
a ih 966 ,or if you want a turbo a 1066 these tractors can be turned up to about 200 or more hp, they are lots of them around they are cheap to buy and parts are plentiful.and they really PULL
caseman
03-20-2001 11:02:46
The GVI is a good choice, I would recommend the Case 600/900. Can go big with big power.
Augie
03-20-2001 10:46:33
G-VI Moline.
Greg H.
03-20-2001 13:13:07
 Re: Re: Tractor Suggestions. in reply to Augie, 03-20-2001 10:46:33
What's the weight of the mm G? and what is realistic HP expectations? Also what can someone expect to pay for that model of tractor?, What part of the country are they more prevalent? Thanks, Greg H.
MM
03-20-2001 14:53:58
 Re: Re: Re: Tractor Suggestions. in reply to Greg H., 03-20-2001 13:13:07
It is a G VI (say G 6). You can buy a good one for 1500 to 2500. The motor is a 425cid. 4.25 bore x 5 stroke 6 cylinders. Take the motor out and sell it. Buy a HD800 MM motor 5.319 bore x 6 stroke. About 2500 will get you one that runs. Put 1000 in in new rings, bearings and some extra stuff to get the motor in. Add 1000 more for paint and some good 18.4x38 tires. You now have a tracor that can pull and win the 7500 to 10000 classes.
The stock HD800 on LP gas, will put out about 275hp. It is a very dependable motor. You will never find any thing better for the money. If you want more power, add a turbo and you can get it over 750hp. More work and money, but still better than the other brands.
Mike
03-21-2001 08:10:48
 Re: Re: Re: Re: Tractor Suggestions. in reply to MM, 03-20-2001 14:53:58
Were do you get one of these HD800 motors? were they industrial motors? where were they used? Can you get the 275 HP without any fancy carb, cam, or head/valve work? Not really interested in building one, just interested in the history/etc.
Mike
