88 starter
KG
03-01-2003 17:39:41
I have a friend with a big cube oliver and is having starter trouble.Any ideals or sources for a heavier starter. THANKS
u2
03-03-2003 06:38:38
 Re: 88 starter in reply to KG, 03-01-2003 17:39:41
call this man 217 589 4045 8am to 5pm he has what you want
Cody Adgent
03-01-2003 18:29:55
Get a starter off of a 6.9 ford diesel motor. They were available in the older model trucks. Should bolt right on and whip the fire out of it!
steve
03-01-2003 20:02:30
 Re: Re: 88 starter in reply to Cody Adgent, 03-01-2003 18:29:55
Your friend can also use a starter from a newer style 88 or super 88 diesel. His local starter and alternator store will have gear reduction starters that will match up with his old starter gears and mounting plate.
Cody Adgent
03-02-2003 09:05:35
 Re: Re: Re: 88 starter in reply to steve, 03-01-2003 20:02:30
The ford starter is a gear reduction starter that is about 10lbs lighter, 10x more powerful and will bolt right up. The local NAPA should have them in stock. If not I've got a good one that I'll take $250 for.
Jerry B
03-03-2003 08:24:30
 Re: Re: Re: Re: 88 starter in reply to Cody Adgent, 03-02-2003 09:05:35
Does the Ford starter work with the Oliver diesel flywheel or the gas flywheel? They ARE different.
KG
03-02-2003 16:39:21
Thanks guys for the info,and i will tell him about your starter Cody Agent Thanks Again.
Cody Adgent
03-04-2003 07:24:11
 Re: Re: Re: Re: Re: 88 starter in reply to KG, 03-02-2003 16:39:21
The Ford starters work with a gas flywheel and bellhousing. Bolts right up!
