Scatter blanket
tractor puller
03-01-2003 08:37:30
i was wonderin how you would go at cleaning a scatter blanket? I had a major rear seal leak and have major oil build up on the blanket and want to get it out of it. Can you soak these things in water and some kind of soap to get them clean or will soaking them wreck them
Thanks in advance
puller fan
03-01-2003 12:24:01
 Re: scatter blanket in reply to tractor puller, 03-01-2003 08:37:30
Simple green works wonders on everything and is "friendly"
G-MAN
03-01-2003 10:12:32
I think I would contact the manufacturer of the blanket. I wouldn't be so worried about the fact that the blanket is dirty, but more worried about what effect that engine oil will have on the materials the blanket is made out of. Engine oil can be pretty hard on some plastics and synthetic fabrics. You'd better make sure the effectiveness of the blanket won't be reduced by the oil or whatever you try to clean it with, for safety's sake.
