88 stroker
bgar
02-28-2003 21:19:32
How much can u stroke a oliver 88?
bigmotors
03-02-2003 22:42:05
 Re: 88 stroker in reply to bgar, 02-28-2003 21:19:32
Yes - Like Tim C. said 6.125 will work.
Get ready to do some grinding.
You can run your oil lines on the outside, or run a pinched copper tube on the inside.
2 inch jor. work well. Best to order rods. $225 to $250.00 a rod
If that's out of your price range, try Massey model 65 rods, 2 inch rod 7 inchs long. That would give you a flat top piston, with a 1 inch pin, with a 6 inch crank. Or Mazda rods, like a Ford Courier pickup, around a 2 inch jor. and a little shorter then the 65 rod
Do your homework on pistons to find out what is out there, and who will make you what you want.
Your talking alot of comp. with a 88/880 head.
I know of 3 motors running with a 1.750 jor.
A 5.750/5.875/ and a 6 inch, all have run about 2 years now with no problems.
Good Luck!
ollie puller 2
03-02-2003 06:22:46
where do you put the cam????? ?????do you still use the oil passage in the block??? do you have to go smaller than 2.0 on the rod?? isnt that borderline insanity????? ????? ?
Earl S
03-02-2003 14:30:40
 Re: Re: 88 stroker in reply to ollie puller 2, 03-02-2003 06:22:46
Maybe we don't know anything about these 1 INCH crank pins. (GRIN)(GRIN)
TimC
03-02-2003 19:46:07
 Re: Re: Re: 88 stroker in reply to Earl S, 03-02-2003 14:30:40
I didn't happen to think that not everyone has access to a CNC VMC to make the rods angled. Grind flats on the cam instead of turning and use external oil pump re-plumbed outside. Maybe no problem was a little strong.
TimC
02-28-2003 22:22:58
6.125 is no problem.
