Need some help with head gasket.
Allis Puller
02-19-2003 17:33:40
I've got my WD which should be up around 230-250 lbs of compression {have'nt put it back together yet}. I was running 190 lbs before and my gasket seeped and bubbled what should I do now? Can you buy a copper head gasket or will the stock work with a good sealer. What sealer should I use?
GKB
02-19-2003 19:07:12
 Re: Need some help with head gasket. in reply to Allis Puller, 02-19-2003 17:33:40
take your block&sleeves and have the block decked
make sure all the sleeves are the same height.let the sleeves stick out of the block 10 thousands instead of 4 thousand like factory.also make sure your head is not warped.use a felpro headgasket.i did this on 2 motors that i have built and it worked great.
Winner
02-19-2003 18:49:06
Try headgasket.com
