Why not make a div 6 for the upper classes with limets and pull jd case and ih and others .
gone green
02-14-2003 13:17:14
farmallgod
02-18-2003 07:39:57
 Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to gone green, 02-14-2003 13:17:14
You know you guys who want this obviously have more money than brains so why don't you join the NTPA,or the ATPA build a super stock or something else and stop messing with the poor guys who can't afford to build a hot rod.
Midwest Puller
02-18-2003 18:38:56
 Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to farmallgod, 02-18-2003 07:39:57
Some guys get a kick out of beating up on people who are on a budget 25% of theirs or less. It's alot more fun than running in the class they belong in and getting beat every so often!
farmallgod
02-18-2003 20:25:23
 Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to Midwest Puller, 02-18-2003 18:38:56
AMEN!!!!! !!!!! !!!!! !!!!! !!!!! !!!
H
02-15-2003 04:57:50
Sound's like fun, count me in.
KFB
02-14-2003 15:12:33
> 1963 and older (why: I don't know - my wife says anything over 40 should be an antique)
> Less than 400 cu in. (why: keep cost down and later motors plugged into newer tractors - like that could be controlled)
> Stock pump and injectors (applies to diesel only), (why: no later inline pumps, but if carb type isn't controlled then pumps could be modified.
> Turbo - maybe (why not: cost)
> RPM's - 20%
> Help the sluggish economy by getting new pullers built, not that it would mean more pullers and save some old tractors from made into ammo for Sadam - then again it would be neat to see a 4010 sent up his intestinal track.
Just a few thoughts and one opinion.
laipuller
02-15-2003 22:21:29
 Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to KFB, 02-14-2003 15:12:33
sounds one sided to me that would rule out STOCK case l/la and mm g's right off the bat, those are just a couple that i know are 400 + stock. must be an oliver or ih puller making this up.
G-MAN
02-15-2003 16:08:46
Why the under 400 cubes rule? Aren't there Div 4 adn 5 tractors of several brands running more than that already? If you're going to have a Div 6, it's going to have to be sustantially better and more entertaining than Div 5, or what's the point? I say let them go crazy. My two cents.
CUBE NUT!!!
02-15-2003 17:37:22
 Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to G-MAN, 02-15-2003 16:08:46
I agree with G-MAN THERES NO REPLACEMENT FOR DISPLACEMENT!!!!!
Troy
02-15-2003 19:13:03
 Re: Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to CUBE NUT!!!, 02-15-2003 17:37:22
Throw turbos in and add more safty equipment. AND THEN LET THEM GO!!!
gone green
02-16-2003 07:53:40
 Re: Re: Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to Troy, 02-15-2003 19:13:03
sounds good to me to John deere with a turbo wounder what it would do. put some more saftyes on and go. div 6 let them all in up to 1970 would make thing neet to see.
Jeff
02-16-2003 12:04:42
 Re: Re: Re: Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to gone green , 02-16-2003 07:53:40
Could do it like the truck pullers did when they let trucks with blowers run in the same class as ones without. Without a blower you would run unlimited cubes but with one you had to stay down around 525 or so i think. It more or less makes for a more even playing field so tht no one had a major advantage. Honestly that is the best way to keep a sport going cause if there is a MAJOR advantage one way or the other alot of folks just quit because there is no chance of winning. And lets face it,if the rules are set up so that for example the M_M's have such a big advantage no one else can come close to them who is going to pull? Watching a pull with all one brand or all one model gets real boring real fast.
Midwest Puller
02-16-2003 13:47:21
 Re: Re: Re: Re: Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to Jeff, 02-16-2003 12:04:42
It seems to me that there are organizations all over the USA that already have the exact class you are talking about. Some call it farm stock, some call it hot farm, it is even called pro field in the south. If that is what you want to do, go find a rulebook and get to work on your tractor!
We have to many divisions and organizations the way it is. What we need is more participation in the clubs that do exist.
KFB
02-16-2003 14:36:03
 Re: Re: Re: Re: Re: Re: Re: Re: Why not make a div 6 for the upper classes with limets and pull jd case and ih and others . in reply to Midwest Puller, 02-16-2003 13:47:21
Yep, your right. I'll just go pull these "hot farm" classes that have you going up against 1066's from July to August and sit around until the next year rolls around. But if there was a division 6, then I guess I might go to a few more pulls in the winter. 10 years from now the 1958 rule will still apply and you know where I won't be.
