U moline
molineman
02-12-2003 18:28:10
need help need to get rear hub off u moline has rear wheel weight inside .it is smaller than the hub .took tire and rim off tried wd 40 rustbuster pb blaster even had it heated red hot with the torch and had a homemade puller on it made of boiler plate it want buge ..some one said the u has a tapered axle and to heat the hub again and hit the end of the axle with a big hammer and it would pop right off.thanks for any help
