660 diesel puller
Farmall Daddy
02-10-2003 17:28:00
Which 660 should I look for, gas or diesel? One of my friends has a diesel with a M&W turbo on it and he cranks 98 horsepower. In my area, turbos are usually not allowed. I imagine you can do more to the gas than the diesel. What do you guys think?
Farmall Daddy
StockPuller
02-16-2003 18:38:40
 Re: 660 diesel puller in reply to Farmall Daddy, 02-10-2003 17:28:00
Hey...To all you guys building up your 660's and wondering if they will hold together...I've got a stock 660 diesel that I farm and pull with that has beat every 830 John Deere that I've came up against...so at times you dont need to build them up to send them to the trailer with their tails dragging between their legs!!! But sure would like to see one with a Turbo on it!!!!
Brandyhaven holsteins
07-13-2005 16:21:20
 Re: Re: 660 diesel puller in reply to StockPuller, 02-16-2003 18:38:40
I have a 660 diesel also.
I was just wondering how well it really pulls.
will it out pull 77 gas oliver?
My dad and i have finally got it together and we are entering it in a pull in listowel ont. saturday.
Is there any way to ship parts from the USA to Canada ont?
E J
02-12-2003 21:06:30
I have 560 d with a 301 cid off of a 715 combine with charger makes 130hp grind feed 3 times a week with it runs fine.
KEV
02-11-2003 18:22:17
I have A 560 wheatland diesel with the T606 turbo on it, ran it on the dyno and it put out 115hp.
Your hp will depend on how much you turn up the fuel.
Generally more fuel more power till you run out of air.
Remember they only hold together so long with this kind of HP.
KEV
77 puller
02-11-2003 13:04:29
If you can get 98 out of a 660 D than I would say that's the way to go! I have never heard of anyone getting anywhere close to that much out of a gas 660, or a 660 period. That would be pretty impressive!
proven fact
02-12-2003 16:37:51
 Re: Re: 660 diesel puller in reply to 77 puller, 02-11-2003 13:04:29
we have a c-301 stroker aka 806 engine in a 460 putting out 240hp @5500 rpms
What kind of test
02-13-2003 18:34:35
 Re: Re: Re: 660 diesel puller in reply to proven fact, 02-12-2003 16:37:51
Is it turbo charged or nat. asp. How do you dyno this machine no way 460 pto will hold up to this.Just wondering how you reached this magic number.
C -301 FYI
02-14-2003 12:43:08
 Re: Re: Re: Re: 660 diesel puller in reply to What kind of test, 02-13-2003 18:34:35
Easy its a gas c 301 with up draft carb running 132 octane. we built it to the max using the best parts steel crank alum. rods Arias pistons Extensive head and valve work ect. and we had it dyno tuned on an automotive engine dyno... Never know you might see it show up in your town..
