Pullingm
farmitallm
02-10-2003 09:21:49
just bought a 44m and am planning on pulling it in almost stock classes(aka no stroked crank)need to know what to do to it to get as much power as possable.pistons,cam,valves;eny and all help will be apreciated.
Farmall Daddy
02-10-2003 13:16:33
 Re: pullingm in reply to farmitallm, 02-10-2003 09:21:49
If you are fouling plugs, try checking the exhaust valves. I had the same proble too, but we decided to overhaul it.
Farmall Daddy
02-10-2003 13:14:02
If you are just going to pull in the 5500 class, put 4 inch high dome pistons with shorter valves. If you are looking forward to 6500 and up, and pulling only {no farm work} bore it and put 4 1/4 or if you can fit 4 3/8 in it with no sleeves. An M and a 450 motor are the same, just a bigger bore and head, but many 450's in my area run no sleeves. The only possible problem that comes to mind is it will heat up quicker.
306m-puller
02-11-2003 03:58:35
 Re: Re: pullingm in reply to Farmall Daddy, 02-10-2003 13:14:02
I put Denny's 4.31 pistons in my C248 M motor and hit the water jacket before 4.25
randy hall
02-10-2003 18:32:25
a 450 block is cored thicker than an m block. you could never run 4 1/4 or 4 3/8" pistons againest the block with no sleeves in an m block.
IH Man
02-10-2003 09:40:34
If the "M" runs good, tune it up and "get a Hook". The more you modify them the more problems you are going to encounter. Pull it like its made,
you'll have fun and save a bunch of money.
farmitallm
02-10-2003 10:00:28
 Re: Re: pullingm in reply to IH Man, 02-10-2003 09:40:34
it runs but cant keep plugs in it.if it sets and idls very long it fowls them pretty quick doesnt seem to smoke a lotbut doesnt seem to have a lot of compression.
IH Man
02-10-2003 10:24:34
 Re: Re: Re: pullingm in reply to farmitallm, 02-10-2003 10:00:28
If its fouling plugs and not smoking it may not be getting hot enough spark? Use some Autolite #386 plugs gapped at .023, put a bottle of Lucas Oil additive in the crankcase to help seal up wore valve seals and try it. Adjust the carb by running the bottom mixture screw in slowly as the engine is running about 1/3 open throttle,as the engine begins to slow down back it out until it runs the fastest speed and leave right there. That Lucas Oil additive will help any seal leaks plus give you a l;ittle ring seal on a tired motor. Give it a shot..... ..have fun
